楼主: 追風sky
有用過Agip RACING 的大大 留點言唷^^ 謝囉
发表于 2005-7-9 01:14:27 | 显示全部楼层
Products
Four Stroke Oil
Agip Racing 4T 10W-60
Agip Racing 4T is 100% synthetic multigrade 4-stroke lubricant, specially designed for use in highly modified multi-valve engines, providing the ultimate in racing performance and protection. Through a full synthetic formula maximum electrochemical bonding, producing a film preventing metal to metal start ups, rapid oil circulation during the warm up phase and exceptional valve train protection as higher speeds are achieved. Powerful anti-foaming agent keeps oil pressure high and heat transfer at a maximum
20x1 liter Case.
(27 .lbs)
  $161.75
這是阿吉普網站copy過來的
應該是機車的罐子
為何會出現汽車的罐子
就不清楚了
會不會跟汽車用的是同一種油?
還有歐洲價格
緊供參考
Agip Racing 4T 5W-40
Agip Racing 4T is 100% synthetic multigrade 4-stroke lubricant, specially designed for use in highly modified multi-valve engines, providing the ultimate in racing performance and protection.  Through a full synthetic formula maximum electrochemical bonding, producing a film preventing metal to metal start ups, rapid oil circulation during the warm up phase and exceptional valve train protection as higher speeds are achieved.  Powerful anti-foaming agent keeps oil pressure high and heat transfer at a maximum.
20x1 liter Case
(27 .lbs)
  $140.74
Agip Racing 4T 20W-50
20x1 liter Case
(45 .lbs)
  $201.68
Agip City 4T 10W-40
     A semi-synthetic multigrade scooter formula 4-stroke blend.
Synthetic scooter formula provides exceptional protection, handles extreme pressures and reduces harmful engine deposits that can diminish power and torque.  Lowers the level of oil consumption.  Particularly suitable for stop and go traffic.  Able to handle higher running temperatures than conventional oil.
20x1 liter Case
(9 .lbs)
  $94.00
緊供參考
发表于 2005-7-9 12:07:47 | 显示全部楼层
回覆給:sam
這一些可能是還沒有更新的資料吧,因為這一些的包裝是04年的樣子,05年的好像是三角瓶的包裝,而且04年的也是有機車包裝的10w60 racing的包裝才對,可以參考一下,謝謝你提供的資料喔!!
 楼主| 发表于 2005-7-13 16:40:29 | 显示全部楼层
請問一下唷!!有高雄人有這罐的嗎??我想跟你買1.2罐來加試試看!!
如果有的話~看哪位大大可以讓我跟他買個1.2罐來加^^
錢多少都ok~不要太超過就好了^^
可以的~回我一下八^^
或加即時通sky20031117@yahoo.com.tw
 楼主| 发表于 2005-7-13 23:18:38 | 显示全部楼层
有的大大~施捨一下八!! 真的很想試試~
等待您唷^^~
发表于 2005-7-14 01:53:42 | 显示全部楼层
回覆給:追風sky
只能說,很抱歉,因為你離我太遠了,一個在北一個在南!!祝你能找到油品供應商。
 楼主| 发表于 2005-7-14 23:32:25 | 显示全部楼层
大寶 你讓我覺得最溫暖了 謝謝你...雖然你不可以...但還是說一聲  謝謝你^^~
发表于 2005-7-15 04:15:15 | 显示全部楼层
回覆給:追風sky
不會啦,大家都是喜歡車的人呀!!不過呀,下次有訂貨的話,可以幫你訂,如果你要的話。
我的msn:barbus999@hotmail.com可以來聊聊天,打屁之類的!!
发表于 2005-7-28 02:28:32 | 显示全部楼层
請問各位原廠鵝也可以用這灌Agip Racing10w-60全合成嗎?
发表于 2005-7-28 03:33:23 | 显示全部楼层
我是用富士機油耶....
 楼主| 发表于 2005-7-28 08:18:28 | 显示全部楼层
Agip Racing10w-60可以用阿~大家用起來 評價還不錯阿...
只是車行不建議我用10W-60的..所以我選擇10W-40的...騎起來還不錯唷!!
60的會太濃了...應該說看你騎車的行程...
如果單程有超過40KM的話...那就可以選擇用60的...熱車時間要夠..騎起來比較好期騎~
如果單程只是1X公里...那用40的就可以囉!!
 楼主| 发表于 2005-7-28 08:19:12 | 显示全部楼层
富士的也不錯阿~~
在日本改裝車...排行第一唷!!
 楼主| 发表于 2005-7-29 23:57:56 | 显示全部楼层
復活一下此版版...
問各位使用這貫的大大唷!!你們使用這罐...是用10W-60  還是 10W-40  較多呢??
通常使用10W-60 or 10W-40 的大大 一般都騎多少公里數呢(單程)??
熱車時間都花多久呢??^^
如果熱車時間不夠...會不會出現加油時發現空轉現象呢??
請教一下各位大大...願意分享的說一下唷!!^^
謝謝~
发表于 2005-7-30 01:50:18 | 显示全部楼层
回覆給:追風sky
進來推一下啦~~我個人是使用racing 10w60的為主,至於里程數來說,我是不一定,上課的話來回是大約50公里左右,不過加上有時都是高速在暴走,所以就和里程數沒有太大的關係了!
熱車的話,像是夏天的話,大概一至二分鐘,冬天的話,那就要久一點了!如果是新換上去的新油來說,熱車不夠的話,騎起來像是拖了一個重物般,騎起來不是很順。不過工作溫度上來的話,是不錯用的喔,上次去極限賽車場練車,騎了四小時也沒有什麼問題,而且是愈來愈順!!
GMT+8, 2025-6-29 11:02 , Processed in 0.238083 second(s), 16 queries .
