楼主:
關於機油的問題
 楼主| 发表于 2004-5-28 23:26:25 | 显示全部楼层
嗯~那請問一下我有看到一瓶美浮5w50的金瓶蓋的好用嗎?請問我用那罐可以嗎? 還是有其他幾家的呢?價錢蠻便宜的說~還有如果是訓車期的油是不是隨便加就可以了呢? 新車裡的機油能用嗎? 需要換新的嗎?
发表于 2004-5-29 03:21:18 | 显示全部楼层
回覆給:老K
~~~~~~推推... 老K說的真好!!!
发表于 2004-5-29 03:22:28 | 显示全部楼层
回覆給:龍二
~~~~~~http://tw.f2.pg.photos.yahoo.com/ph/sohc_eg6/my_photos 可以參考一下..
发表于 2004-5-29 08:46:42 | 显示全部楼层
只要別用到假油即可..............汽車機車都差不多啦..........
我們車隊都用頂級汽車油..........
但如果你用汽車油心理會不舒服的話........那情願別用........心情比較重要.......用得開心就好!!!
 楼主| 发表于 2004-5-29 09:17:57 | 显示全部楼层
发表于 2004-5-31 08:33:39 | 显示全部楼层
3Q~^O^~
发表于 2004-5-31 09:10:12 | 显示全部楼层
訓車期出廠油最好換掉,大賣場的油也是可以用啦
发表于 2004-5-31 14:28:10 | 显示全部楼层
新美孚全合成讚
這等價錢這種表現算優的了
至少我的車油耗紀錄就是加這隻油跑出來的
48.8 km/l
之前最好差不多到47km邊緣
很順暢
发表于 2004-5-31 19:30:23 | 显示全部楼层
請問您是騎sv的嗎
可是金美孚的那罐5w-50上面沒寫機車用耶
他寫的是Fully  Synthetic  Motor  Oil
應該是汽車用吧
发表于 2004-6-2 18:17:43 | 显示全部楼层
回覆給:愛車小孩
是汽車用的沒錯
可以到車麗屋或慶徽看看
 楼主| 发表于 2004-6-2 21:58:12 | 显示全部楼层
這瓶金美浮上面是汽車用的沒錯啦,那這樣機車就不能使用嗎?我看各位大大都說買5w50或5w40的最好用,但是我找了半天這樣的規格好像都是汽車用的機油,好像機車用的都是10w40或15w50等等的....那我到底該買那種呀??? 幫忙解答一下吧,感謝~~
 楼主| 发表于 2004-6-3 09:20:54 | 显示全部楼层
发表于 2004-6-3 10:09:42 | 显示全部楼层
台灣的氣候10w-40就可以了
除非你時速都在80以上
那就用15w-50
发表于 2004-6-3 10:23:17 | 显示全部楼层
<script language="javascript" type="text/javascript">
Our product rangeprint version
<script language="javascript">
  4-stroke engine oil
Biker on racetrack
Shell Advance oils are made up of a special mix of top-quality synthetic, semi-synthetic, or mineral base oils.
Special high-performance additives are also mixed in to provide long lasting protection against engine stress and improved cleanliness.
It takes years of oil formulation experience to come up with the right formula for Shell Advance and the way various additives are mixed in with the base oil is crucial to its overall performance.
Key features of Shell Advance 4-stroke oils
  • Uses base oil with built in high viscosity index and excellent shear stability, meaning less viscosity improvers, to keep engines and gearboxes cleaner
  • Additive technology which perfectly suits the requirements of wet clutches
  • High thermal stability to give longerlasting and safer lubrication
  • High evaporative stability and hence lower engine oil consumption
  • High quality anti-wear protection
  • Meets and exceeds highest international specifications (JASO, API)
See the evidence for how Shell Advance keeps your engine cleaner for longer.
Read tips from our experts on how to change your engine oil.
Shell Advance Scooter 4
10W-40 semi-synthetic 4-stroke scooter oil
Shell Advance Scooter 4 bottle
  • Shell Advance Scooter 4 is a unique semi-synthetic scooter engine oil specially formulated for modern high-speed 4-stroke scooter engines
  • The carefully balanced formulation makes it suitable for all scooter types in all conditions
  • It gives excellent engine cleanliness and performance while reducing oil consumption
  • The product exceeds international standards (API - SL and Jaso MA), and meets the requirements of leading scooter manufacturers
電話0800-006-376
僅供參考
发表于 2004-6-8 21:10:14 | 显示全部楼层
機車用油與汽車用油之前已經爭論許久..........信者恆信.......不信者恆不信........
只能就實質來講.........不少人用汽車油.....用的好好的.......而且人也用的很爽......只能說沒啥大問題.........
重要是自己喜歡.......旁邊的人也僅能提供些經驗........
那就我們車隊來說..........幾乎都用汽車油.....而且是高檔的汽車油是法拉利跑車在用的...用起來效果很好..殼牌SHELL ULTRA 5W-40
发表于 2004-6-10 13:09:08 | 显示全部楼层
~~~~~~嗯... 這個問題之前也在我心中困擾很久!? (到底機車可汽車用機油!?)
~~~~~~但我的車現在29XXXkm了! 開始加汽車用機油是在18000km之後的! 車子也都跑過山道整路幾乎全油門在跑的! 車車也都ok!
~~~~~~在未換汽車機由前我問很多人使用後的感覺, 有無意狀, 騎多遠, 騎乘方式...等等!  得到一些資訊後才敢加!     但其實是ok的啦!   就連一些精品店賣的機油也都是有賣汽車用油的@.@
发表于 2004-6-11 00:49:08 | 显示全部楼层
是阿..........蠻多精品店也是有一部分是汽車油..........所以還ok啦.........
只是只是心理不舒服的人或比較個性比較龜毛的.......還是別用為妙........畢竟我們心理都調適得過來才來用汽車油..........
发表于 2004-6-11 01:10:41 | 显示全部楼层
英國俾司麥賽車油.加速超快.尾速超會拖.耐用.非一般機油.效果保證好.真的.需要請電洽0928130082機會難得.請把握.謝謝您
GMT+8, 2025-6-28 03:50 , Processed in 0.155066 second(s), 14 queries .
