楼主: 阿誠
請問各位網友喜歡那一種形式引擎?
发表于 2002-7-16 17:06:56 | 显示全部楼层
二行程V型三汽缸
嗯....
讚!!
发表于 2002-7-16 17:16:25 | 显示全部楼层
沒有人跟我一樣喜歡Moto Guzzi的V-twin嗎?!
嗚嗚...可憐的Guzzi .........
发表于 2002-7-16 17:47:19 | 显示全部楼层
轉子引擎馬力大沒錯,但吃油跟吃水一樣,
引擎型式~~鍾情並列四缸~~
发表于 2002-7-16 17:48:51 | 显示全部楼层
回覆給:無心插柳柳橙汁
有!!!!V-11.......
发表于 2002-7-16 17:53:20 | 显示全部楼层
回覆給:亞力
V-11超美的.........
喔~~~~~~~~~~~~~~~~多美麗的機車啊
(請參照幸運女神中常出現的雙手交握陶醉的表情)
发表于 2002-7-16 17:54:53 | 显示全部楼层
有品味呦!!!!!!
发表于 2002-7-16 18:02:47 | 显示全部楼层
回覆給:阿誠
轉子引擎ㄉ車子??早就有ㄚ@@ 馬自達 當家花蛋 RX-7 FD.就是啦 還有RX-8 也速ㄚ~~
EVO.NSX.GTR.RX-7.硬皮鯊 日本5大天王 都速好車喔^^
发表于 2002-7-16 18:20:04 | 显示全部楼层
還是喜歡暴力的並列汽缸
兇猛加上乾式離合器
发表于 2002-7-16 18:21:50 | 显示全部楼层
The rotary, or Wankel, engine has a number of benefits over standard engines including a lack of camshafts, intake and exhaust valves, and a reduced number of moving parts.
However, Suzuki's introduction of a rotary-engined motorcycle in the 1970s was destined to become an eventual failure. This large motorcycle, while mechanically simple, consumed a whopping 30 to 35 miles per gallon in the gas-conservative 1970s and weighed in at a hefty 573 lbs. Also included was a special heat shield since the rotary engine design tended to make exhaust pipes hot enough to burn riders' legs. To make matters worse, the RE5 tended to buck, pop, and surge as a result of the dual ingition system installed to handle proper timing under conditions of acceleration and deceleration.
However, for all its ungainly operation and idiosyncracies, the rotary RE5 can be respected as an important investigation into the mechanics of motorcycling and has become a very highly regarded collector's item.
Features:
573 pounds (wet)
two-barrel, down-draft, 18-32mm automotive-style carb.
dual oil system to lubricate the engine seals
dual ignition system
30 to 35 mpg fuel consumption
img border="0" src=http://photo.pchome.com.tw/s01/tomacchen/book1/p1s.jpg width=500
发表于 2002-7-16 18:23:11 | 显示全部楼层
发表于 2002-7-16 18:27:17 | 显示全部楼层
ttp://photo.pchome.com.tw/s01/tomacchen/book1/p1.jpg
 楼主| 发表于 2002-7-17 09:07:28 | 显示全部楼层
回覆給:Tomac
抱歉!
因上網時間太少!所以有一些內容隔天才知道!
 楼主| 发表于 2002-7-17 09:11:49 | 显示全部楼层
回覆給:dio小鬼
對不起!我說是摩托車!抱歉我打文字太容易誤會意思!
发表于 2002-7-17 11:23:25 | 显示全部楼层
回覆給:阿誠 機車來講最愛L4 and L6 的引擎設計~這兩種聲浪最好聽,尤其高轉速時﹔真是讓人血脈憤張~~~~
发表于 2002-7-17 11:55:31 | 显示全部楼层
哇!那台像雄獅的是轉子引擎ㄟ!
发表于 2002-7-17 13:49:12 | 显示全部楼层
RC211V........
 楼主| 发表于 2002-7-18 11:22:01 | 显示全部楼层
聽說轉子引擎低轉速扭力不足
WHY ?
謝謝指教!
发表于 2002-7-19 19:49:46 | 显示全部楼层
OOOO....AUDI的W12......還沒聽過聲浪說....><"
发表于 2002-7-22 06:51:28 | 显示全部楼层
F1..V12噴射引擎
发表于 2002-7-22 06:59:17 | 显示全部楼层
回覆給:阿誠
我個人很喜歡V2的引擎~
如果排氣量大在拉轉速時有種特殊的鼓動感~
GMT+8, 2025-7-16 04:40 , Processed in 0.065411 second(s), 14 queries .
