楼主: 騎TZRㄉ阿樂
大家大聲說出心目中喜歡ㄉ重車吧^O^........TZR
发表于 2009-3-10 15:45:37 | 显示全部楼层
RG500...想體驗一下什麼叫抓不住的爆炸感...
MT01.....在我個人心中最完美的配置..V2低轉肌肉引擎+街跑車架...
CB750F......國中時代很哈的一台車.到現在還是覺得很有感覺...
发表于 2009-3-10 16:42:33 | 显示全部楼层
Megelli 125R
发表于 2009-5-20 20:55:18 | 显示全部楼层
09 cbr1000rr
发表于 2009-5-21 00:30:19 | 显示全部楼层
我的夢想車已達成@"@阿魯750
接下來的希望.挖本人特製nsr150ss(超級亂改 )
发表于 2009-5-21 01:05:58 | 显示全部楼层
超哈六眼魔獸的
发表于 2009-5-21 05:35:16 | 显示全部楼层
哈雷豪華版......
发表于 2009-5-21 07:35:11 | 显示全部楼层
Y2K...
不過大概中樂透才有機會:P
[ 文章最後由 s9208282000 於 2009-5-21 07:39 編輯 ]
发表于 2009-5-21 13:51:18 | 显示全部楼层
TZ250........
发表于 2009-5-22 02:03:21 | 显示全部楼层
來一部DUCATI  D16 吧!!!
超想要的
发表于 2009-6-5 00:50:58 | 显示全部楼层
當然是 MotoCzysz C1
[img]http://www.motoczysz.com/images/photos/wallpaper/side_bodywork_tr[img][/img]ans_800.jpg[/img]
General information
Model: MotoCzysz C1 990
Year: 2009
Category: Sport
Rating: 57.7 out of 100. Show full rating and compare with other bikes
Safety: See our safety campaign with the high safety rated bikes in this category.
Engine and transmission
Displacement: 990.00 ccm (60.41 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 220.00 HP (160.6 kW)) @ 15000 RPM
Torque: 108.48 Nm (11.1 kgf-m or 80.0 ft.lbs)
Max RPM: 16000
Bore x stroke: 82.0 x 46.9 mm (3.2 x 1.8 inches)
Fuel system: Injection
Fuel control: OHC
Ignition: 4 plug mounted coils
Starter: Electric
Gearbox: 6-speed
Transmission type
final drive: Chain
Clutch: Dry pack with Hydro electro slipper control
Physical measures
Dry weight: 158.0 kg (348.3 pounds)
Seat height: 780 mm (30.7 inches) If adjustable, lowest setting.
Wheelbase: 1,420 mm (55.9 inches)
Chassis and dimensions
Frame type: Carbon Fiber Frame 5kg with Carbon Fiber Subframe 2.5 kg
Rake (fork angle): 22.5?/TD>
Front suspension: 6X Flex with Ohlins shock
Rear suspension: DUO spring with regressive damped Ohlins shock
Front brakes: Single disc. Brembo Monoblock radial mount calipers
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc. Brembo Monoblock radial mount calipers
Rear brakes diameter: 320 mm (12.6 inches)
Exhaust system: FMF Titanium 45mm 4-2-4
Speed and acceleration
Power/weight ratio: 1.3924 HP/kg
Other specifications
Fuel capacity: 7.57 litres (2.00 gallons)
Color options: Silver/black/red
Comments: Z-Line 4 engine. Twin Crank/ Triple OHC. Limited edition of 50 bikes.
Further information
Parts and accessories Check out parts and accessories from our partners.
Ask questions Join the 09 MotoCzysz C1 990 discussion group,
the new MotoCzysz forum at Bikez.name or
the new Sport forum at Bikez.name.
Insurance, loans, tests  Check out insurance here. Search the web for dealers, loan costs, tests, customizing, etc.
Related bikes List related bikes for comparison of specs
[ 文章最後由 93a1040 於 2009-6-5 00:58 編輯 ]
发表于 2009-6-5 01:02:16 | 显示全部楼层
回應 190# 93a1040 的文章
要是這台能參加sbk....車子設定ok..車手中上程度..大概無敵吧..超級威的車阿..它比雙凸還先進..是三凸..引擎不是直四也不是v4..是z4     Z-Line 4 engine. Twin Crank/ Triple OHC. Limited edition of 50 bikes.
車重158KG 也是市售公升仿賽不可及的
[ 文章最後由 93a1040 於 2009-6-5 01:30 編輯 ]
发表于 2009-6-5 01:13:27 | 显示全部楼层
回應 191# 93a1040 的文章
好特殊的一台車.....
俺要R1 R6 R7.......
发表于 2009-6-5 01:31:09 | 显示全部楼层
回應 191# 93a1040 的文章
我沒記錯的話
那台是沒有陀螺效應那台嗎?
发表于 2009-6-5 09:55:33 | 显示全部楼层
回應 193# nsmx1rex 的文章
沒錯...你真有眼光..
发表于 2009-6-26 12:53:30 | 显示全部楼层
心目中的第一名-H牌 RVF-750
               第二名-Y牌 YZF-R7
:P 唉-不小心透露出年紀
发表于 2009-6-26 17:41:19 | 显示全部楼层
回應 195# hrc9594 的文章
R7台灣有/ 忍者7號美規之前也很多
都是之前市售的正規賽車喔
发表于 2009-6-26 19:43:57 | 显示全部楼层
其實尾最喜歡蝙蝠俠的車!
发表于 2009-8-5 00:49:56 | 显示全部楼层
我喜歡老車~~初代的900RR.XX.CB400初代(很友男人味)FZR400RR. BANDIT400
新車外型實在是............喜好不同啦~~
发表于 2009-11-27 06:29:53 | 显示全部楼层
RSV4 ...............
光看都快高潮了................
发表于 2010-1-3 17:51:48 | 显示全部楼层
Honda RC166
..有人喜歡這種老怪物嗎.....好想現場聽一下這種車拉轉的聲音
GMT+8, 2025-12-12 08:21 , Processed in 0.075927 second(s), 19 queries .
