查看: 438|回复: 1
論文中一些專有名詞和語意上翻譯的問題
发表于 2006-10-10 14:28:02 | 显示全部楼层 |阅读模式
這幾天研讀一篇稐文遇到一些瓶頸...
一些專有名詞和文字段落翻不出創的語意
如果有大大有空或是剛好閒著發荒就拜託替我解解惑>"<
這邊會列出來的都是已經實在沒辦法的部分
1.Web-Conscious Storage Management for Web Proxies
2.user-level disk management
3.Using realistic trace-driven simulations we show that the proxy’s
4.secondary storage I/O throughput can be improved by a factor of 18,
enabling a single-disk proxy to serve around 500 (URL-get) operations per
second.
5.Our experimental evaluation suggests that Foxy outperforms
traditional proxies such as SQUID by more than a factor of 7 under heavy
load.
6.non-caching mode
7.proof-of-concept proxy server
8.cache miss
9.data-locality
10.Most of the meta-data overhead that cripples web proxy performance can
be traced to the storage of each URL
in a separate file.
11.To eliminate this performance bottleneck we propose a novel URL-grouping
method (called
BUDDY), in which we store all the URLs into a small number of files.
12.Towards this end, we develop a file-space management algorithm (called
STREAM) that (much-like log-structured file systems) streams write
operations to the disk: The web proxy stores all URLs in a single file
organized in slots of 512 bytes long. Each URL occupies an integer number
of (usually) contiguous slots.
13.LAZY-READS technique
14.NURL
15.consider the case of an HTML page that contains several embedded
images.
16.A first step towards improving the performance of read operations,
LAZYREADS, reduce this overhead by clustering several read operations
and by sending them to the disk together. This
grouping of read requests not only reduces the disk head ping-pong effect
but also presents the system with better
opportunities for disk head scheduling.
17.ping-pong effect
另外還有三張圖
麻煩大家了
发表于 2006-10-11 18:09:01 | 显示全部楼层
回覆給:單眼皮一.一
小弟不才0.0...我雖然是高3資訊科 可是大多都是看書自修比較多
這個PROXY 沒學過
0.0...
這個應該只是網路基本架構吧
買書就有答案哩
GMT+8, 2025-7-11 07:52 , Processed in 0.063668 second(s), 20 queries .
