楼主: b1137
不好意思~請問 一下大家一個問題?
发表于 2009-11-25 16:48:50 | 显示全部楼层
我是雨夜小~不是大!!!!
是 F!!!!!!!!!! FCUP!!沒錯!
发表于 2009-11-25 16:52:09 | 显示全部楼层
回應 21# killer119 的文章
比我還老還敢說自己小= = "
誰幫我叫一下救護車
謝謝
[ 文章最後由 pighead48 於 2009-11-25 17:18 編輯 ]
发表于 2009-11-25 23:59:44 | 显示全部楼层
回應 22# pighead48 的文章
來了來了~~
EE勾 (119) 來了
果然選E(以上皆是) 跟 選E(以上皆非) 都會被打勾啊~
原來K女深奧的話語中是充滿了玄機
藉此點悟世人
佩服佩服
发表于 2009-11-26 08:23:07 | 显示全部楼层
回應 23# taco 的文章
麻煩把雨夜大載走
我哪有語藏玄機阿= = "
 楼主| 发表于 2009-12-1 01:14:30 | 显示全部楼层
這是這篇的摘要:
In an effort to increase the detectability of a motorcycle’s brake signal, this study evaluated the effects of a modified stop lamp formotorcycles.
With this modified stop lamp, both turn signals would flash simultaneously to supplement the regular stop lamp. The major concern with this design is the confusion between regular turn signals and the modified stop lamp with both turn signals flashing.
Two experiments were conducted to evaluate this design using a PC based driving simulator equipped with three motorcycle taillight assemblies. The results suggest that the reaction time to a brake signal can be significantly reduced by 200 ms on average (po0.001) with a modified stop lamp, especially during the night when a taillight is on (po0.05). Although the normal use of a turn signal was affected by the use of a modified stop lamp by approximately 122 ms (po0.001), this adverse influence does not exist for a motorcycle that is straight ahead (po0.01). When regular turn signals are present, they do interfere with the use of a modified stop lamp by an average of 134 ms (po0.05). However, even with such interference, this design still requires a shorter reaction time than a conventional stop lamp by about 120 ms (po0.05). Overall, it can be concluded that even with the interference, the reaction time to modified stop lamps is still shorter than the reaction time to the conventional stop lamps in laboratory settings.
這樣各位大大們應該會比較知道在講什麽吧.....小弟我還是一知半解=.=
发表于 2009-12-2 10:27:52 | 显示全部楼层
回應 25# b1137 的文章
これは何??
這是什麼??= = "
GMT+8, 2025-6-14 12:37 , Processed in 0.114852 second(s), 15 queries .
