查看: 3282|回复: 9
[分享] Bikex.com 機車年鑑網站
发表于 2009-3-25 13:55:46 | 显示全部楼层 |阅读模式
发表于 2009-3-25 18:17:55 | 显示全部楼层
原文由 viper0355 於 2009-3-25 13:55 發表
Bikez.com
這是一個機車年鑑網站,可以查詢1970到2009大部分的市售車,還包含一些
改裝廠的特式車...有興趣的可以看看
PGO G-MAX 50<二行程> ....2008.......=.=""
http://www.bikez.com/motorcycles/pgo_g-max_50_2008.php
General moped information
Model:PGO G-MAX 50
Year:2008
Category:Scooter
Rating:75.9 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement:49.00 ccm (2.99 cubic inches)
Engine type:Single cylinder
Stroke:2
Power:3.08 HP (2.2 kW)) @ 6250 RPM
Torque:3.50 Nm (0.4 kgf-m or 2.6 ft.lbs) @ 5000 RPM
Compression:6.8:1
Bore x stroke:40.0 x 39.2 mm (1.6 x 1.5 inches)
Fuel system:Carburettor
Ignition:CDI
Starter:Electric & kick
Lubrication system:Separation
Cooling system:Air
Gearbox:Automatic
Physical measures
Weight incl. oil, gas, etc:105.0 kg (231.5 pounds)
Seat height:820 mm (32.3 inches) If adjustable, lowest setting.
Overall height:1,170 mm (46.1 inches)
Overall length:1,855 mm (73.0 inches)
Overall width:730 mm (28.7 inches)
Wheelbase:1,365 mm (53.7 inches)
Chassis and dimensions
Front tyre dimensions:120/70-12
Rear tyre dimensions:130/70-12
Front brakes:Single disc
Rear brakes:Expanding brake (drum brake)
Speed and acceleration
Other specifications
Fuel capacity:7.50 litres (1.98 gallons)
Comments:Taiwan made bike.
Further information
Parts and accessoriesCheck out parts and accessories from our partners.
Ask questionsJoin the 08 PGO G-MAX 50 discussion group,
the new PGO forum at Bikez.name or
the new Scooter forum at Bikez.name.
Insurance, loans, tests Search the web for dealers, loan and insurance costs, tests, customizing, etc.
Related bikesList related bikes for comparison of specs
真的有上市過嗎....真懷疑....一.一
发表于 2009-3-25 23:29:41 | 显示全部楼层
回應 2# cjo407 的文章
這台有上市喔~~~~不過不是在台灣
比G-MAX200輕了45公斤
 楼主| 发表于 2009-3-26 02:33:37 | 显示全部楼层
发表于 2009-3-26 11:41:26 | 显示全部楼层
好東西...我加到Z的首頁了
发表于 2009-3-28 01:07:37 | 显示全部楼层
原文由 viper0355 於 2009-3-26 02:33 發表
這是針對歐洲國家所推出的車款= =a,基本上歐盟三期能過就能上市,2009年好像改四期了,很多2T125都是降馬力、原廠管能過歐盟三期,過訓車期後找代理商換上解封印套件,就可以全馬力輸出,只有台灣的腦殘官員,硬要把環保法規弄成全 ...
移民到香港,我想你連車都沒得騎= =
我去年在香港住了幾個月,看到在路上騎乘的重車可能不到10台
就連速克達都很少,四輪的屌車也少見
可能我在住在九龍,那個地方玩車的人少吧!!
曾經有想過要去公主道找sky,不知道他在不在................
 楼主| 发表于 2009-3-28 01:42:06 | 显示全部楼层
发表于 2009-3-30 22:57:55 | 显示全部楼层
G-MAX 50應該是2T的吧?
要不然那麼神勇的外型 動力卻.... 還蠻可怕的啦XD
发表于 2009-3-31 02:22:38 | 显示全部楼层
那個網頁有毒:@
只要一點我的小雨傘就跳出來…看不到呀~:\'(
 楼主| 发表于 2009-3-31 12:02:21 | 显示全部楼层
GMT+8, 2025-5-12 21:47 , Processed in 0.071025 second(s), 19 queries .
