楼主: Slick_Kev
FZ保養 Question
发表于 2009-2-16 13:29:57 | 显示全部楼层
回應 15# Slick_Kev 的文章
u said  I live in Tao Yuan City but I study in Guan Du.  i think u can go out with some friends here.  they usually have some meeting or parties.  u can to the here <桃竹車友區>..da area will be close u.  and i guess u can speak but  just can't write in chinese, right?  go out with them, da will be the fast way to get any kind of infor.
and if u wanna know which body shop is better ......i will tell u, the best body shop is urself.  why?...save more money and nobody will take care of ur bike like u.....
i had been  in 416 area....but stay in chinese area.  da's why my english still poor.
well, about the oil, u can try Agip 10W60...this one is for racing. Much ppl recommend this one....and the cooling system...u can change ur oil cooler to bigger one.  i wll suggest u to use this one http://tw.f4.page.bid.yahoo.com/ ... 470?u=d2_luca...and u can buy it from Luca.
or u can add my msn m3kw1979@hotmail.com we can chat there.  ^^ btw, my name is Kevin ...nice to meet u..
发表于 2009-2-16 13:45:51 | 显示全部楼层
看的好頭痛= =.....
发表于 2009-2-16 14:04:42 | 显示全部楼层
本來就是該這樣
確定真的不懂的
就請各位耐下心來指導
不要都砲來砲去的
新人的熱心會被澆熄的...
发表于 2009-2-16 15:31:51 | 显示全部楼层
1.You need a good workkshop . In there , no too much man can fix / maintnance .
2.Good oil keep your bike good . Use AGIP or IP Oils . ( NZV996 - Kevin say .. ) MA class
3.Oil need 2L one time.
4.202cc keep 428 chain , but the type need to use HavryDuty Chain . Like RK428HS (keep clean)
5.Start the bkie ...when the oli temp upto work temp .. than can drivie .
to find maintnance guide..
1.你需要有良好的維修廠(車行),國內真的會修的人很少.
2.好的機油讓你的車況好。同NZV996 - Kevin 所說的,使用AGIP機油或IP機油。必須注意要有MA規範
3.每次機油交換量為2L
4.202cc的排氣量,使用428重責務鏈條即可,如RK428HS
5.行駛前請確定暖車,讓機油達到工作溫度
6.請加中油直營無鉛汽油
7.保持車輛清潔
You need friend with the bike... FZ/R .
http://www.zclub.com.tw/discuz/v ... &extra=page%3D1
Data From.. Zclub and C.F.T.~熊爺~
[ 文章最後由 fox 於 2009-2-16 15:34 編輯 ]
发表于 2009-2-16 15:34:48 | 显示全部楼层
他是華僑..他只會看中文.不會寫跟打...而且他已經買了FZ了.在桃園..還是學生的身份........
我想不要因為他只會打英文..而排斥他對吧....已經有跟他說可以先去那裡吸收資訊了.....等他在有問題..在跟他說吧..........
而且..英文一直是台灣人的一各很難進步的地方.....如果有去過香港..你就會明白到我們的英文真的會很難進步....因為我們會排斥........讓我們一起進步吧..^^
发表于 2009-2-16 15:38:15 | 显示全部楼层
試著看XD...
雖然看得很辛苦XD
发表于 2009-2-16 15:48:16 | 显示全部楼层
回應 26# bestlove413 的文章
算美語或會話吧~跟英文有很大的差異,使用上及字眼上,有時必須要懂相關文化才懂
跟台灣國語是差不多的狀況
看了頭很大很大~(←頭很大的英文要怎麼翻勒?是字譯或意譯!有夠頭大的... 翻譯真是件難事)
发表于 2009-2-16 15:55:29 | 显示全部楼层
插個花!!!在情人節當天 約六七點 士林往大度路方向的藍色FZ2到底是誰呀!!
z版不是有認車友的版嗎!?!我怎麼遍尋不著...
[ 文章最後由 fbi66615 於 2009-2-16 16:19 編輯 ]
发表于 2009-2-16 16:22:21 | 显示全部楼层
看Z版
學英文
发表于 2009-2-16 16:39:24 | 显示全部楼层
回應 4# a0986898662 的文章
你的圖太"鬼畜" 我快受不了了  好想犯案呀!!!!
[ 文章最後由 fbi66615 於 2009-2-16 16:43 編輯 ]
发表于 2009-2-16 16:44:38 | 显示全部楼层
回應 25# m3_kevin 的文章
我不會排斥他低~
我還希望他教我英文勒~"~
发表于 2009-2-16 18:25:26 | 显示全部楼层
回應 31# zxcvbnm230 的文章
我不會排斥他低~
我還希望他教我英文勒~"~
+1
发表于 2009-2-16 18:35:27 | 显示全部楼层
英文看不懂...
複製貼上WORD...轉成繁體中文
大體是什麼意思應該是OK
我還以為是屏科的勒~屏科有位騎FZR的外國人O_O
发表于 2009-2-16 18:46:16 | 显示全部楼层
那前提你需要在桃園..^^..你交他車子..他交你英文...^^....
不過樓主..怎麼不見了?...^^......
发表于 2009-2-16 19:07:41 | 显示全部楼层
原文由 m3_kevin 於 2009-2-16 18:46 發表
這是除了教課書的英文之外..我看的比較認真的 ^^
原po說他電系有整理過線路..引擎改202...(一些口語字詞..只能猜看看)
您有提到地區代碼(416)...很好奇是那一個國家耶..新加坡嗎?
发表于 2009-2-16 21:34:03 | 显示全部楼层
回應 34# m3_kevin 的文章
好遠= =....
我住高雄耶....
发表于 2009-2-16 21:38:10 | 显示全部楼层
車主在關渡唸書...算淡水區......
個人是覺得當面交流討論比較快...
英打真滴很累...讀滴人更累...
跟英文很久沒見了說...:$
发表于 2009-2-16 22:24:26 | 显示全部楼层
版大消失勒@@"
 楼主| 发表于 2009-2-16 22:51:20 | 显示全部楼层
回應 21# m3_kevin 的文章
Sich. Great  to have a Kevin with a cell of 416. Thanks for the info bud, unfortunatly I don't know anything about fixing bikes or have any tools.
 楼主| 发表于 2009-2-16 22:57:51 | 显示全部楼层
回應 24# fox 的文章
Thanks for the translation bud! Must've been difficult for you to read and translate, I really appreciate you helping. So far I've been doing what you've said except for the chain part. I'm not sure what type that is. I use a standard chain that you must lube your self. I have no temp gauge since I own a FZ I. I seen you post alot must be an operator or something?
GMT+8, 2025-6-25 08:36 , Processed in 0.199532 second(s), 15 queries .
