查看: 1633|回复: 13
6S自行安裝HID與大家分享
发表于 2007-11-12 00:01:44 | 显示全部楼层 |阅读模式
[color=darkred]除了HID是買現成的外.其他所有零件都是在電料行買來加工的[/color]
[img]http://lh6.google.com/roxer123/RzZiKXB-yBI/AAAAAAAABVw/d32BTvOPqZ0/s640/P1000781.jpg[/img]
[color=darkred]車麗屋買的.H7型6000K一組兩千六.另一組在家備用.大陸貨應該很快就掛點吧[/color]
[img]http://lh3.google.com/roxer123/RzZiKnB-yCI/AAAAAAAABV4/wgTD_jJDRu0/s640/P1000782.jpg[/img]
[color=darkred]原本右眼近燈是H7型.左眼遠燈是H4遠近燈型但只使用遠光.打算HID使用電瓶電.拿H7的電源來供給H4使用.在使用H7的電源來當作繼電器的控制電流.這樣就可使用H4的近遠燈與HID的燈具獨立了.[/color]
[size=18]HID電源接頭與開關和保險絲.[/size]
 [img]http://lh3.google.com/roxer123/RzZiKnB-yDI/AAAAAAAABWA/prxgzvKjnbU/s640/P1000783.jpg[/img]
[size=18]追加的三用點煙器與USB接頭.[/size]
[img]http://lh4.google.com/roxer123/RzZiK3B-yFI/AAAAAAAABWQ/Cezd9fjAoTo/s640/P1000785.jpg[/img]
[size=18]H4用的加強燈座.多達買的.材質為陶瓷.老闆說不能摔.會破.[/size]
[img]http://lh5.google.com/roxer123/RzZiXHB-yGI/AAAAAAAABWY/5AijO56AGnY/s640/P1000786.jpg[/img]
[size=18]這就是繼電器了.我只使用到單邊.另一邊可以拿來擴充.[/size]
[img]http://lh5.google.com/roxer123/RzZiXHB-yHI/AAAAAAAABWg/oNXLbFDqXd4/s640/P1000789.jpg[/img]
[size=18]兩個開關.一個是HID獨立開關.一個是H4燈泡開關,由於是接自原近燈燈泡所以為常時開.但是如果需要也是可以全關掉的.[/size]
[img]http://lh6.google.com/roxer123/RzZnQXB-yQI/AAAAAAAABXs/d1UvnQXwuN8/s640/P1000799.jpg[/img]
[size=18]點煙器位置想了很久.決定就這吧[/size]
[img]http://lh4.google.com/roxer123/RzZnQ3B-yTI/AAAAAAAABYE/FaAfdYD2dP4/s640/P1000804.jpg[/img]
[color=red][size=18]成果展[/size][/color]
[size=18]全時關[/size]
[img]http://lh4.google.com/roxer123/RzZnQ3B-yUI/AAAAAAAABYM/qAb6pwBx_10/s640/P1000805.jpg[/img]
[size=18]H4的近燈(感覺不是很亮.焦距太近了嘛?)[/size]
[img]http://lh6.google.com/roxer123/RzZoiXB-yVI/AAAAAAAABYU/stjgtK8HTGI/s640/P1000806.jpg[/img]
[size=18]H4的遠燈[/size]
[img]http://lh6.google.com/roxer123/RzZoiXB-yWI/AAAAAAAABYc/jsmY1Iw4Yag/s640/P1000807.jpg[/img]
[size=18]單眼H7型HID上場啦~~[/size]
[img]http://lh6.google.com/roxer123/RzZoiXB-yYI/AAAAAAAABYs/N15jonmHZ6w/s640/P1000810.jpg[/img]
[size=18]對向來看不管怎麼看都刺眼.看來只有山道限定了[/size]
[img]http://lh6.google.com/roxer123/RzZoiXB-yXI/AAAAAAAABYk/NCGEPwb_PQE/s640/P1000809.jpg[/img]
如果有興趣研究接線的.可以進來看詳圖.有些藏線的圖我省略了http://picasaweb.google.com/roxer123/JDqAuC
 楼主| 发表于 2007-11-12 00:17:19 | 显示全部楼层
HID電源接頭與開關和保險絲
追加的三用點煙器與USB接頭
點煙器位置想了很久.決定就這吧.
成果展
全時關
H4的遠燈
單眼H7型HID上場啦~~
路過的  发表于 2007-11-12 00:19:20
回覆給:SEGA
你這樣下雨天開關會進水吧>"<
你可以去買這種有防水蓋的^^
如果沒看錯停車場還有一台360喔^^
使用道具
 楼主| 发表于 2007-11-12 00:21:58 | 显示全部楼层
HI~FREEMAN還沒睡?
我在賣場沒找到你說的這種塑膠軟墊.我還在想要買哪種糖果蓋子來遮點煙器的孔呢...
路過的  发表于 2007-11-12 00:31:59
回覆給:SEGA
對啊!明天放假呗^^
你可以去買金吉邁500的手機充電器插座(我們都說點煙器.不過他們聽不懂=.=")
開關防水蓋電子材料行有很多種..有一是上面有2組開關的
(我目前裝這種.照片上是一組而已.我換的這種還沒照片檔)
如果你們那有電子材料行..應該就有點煙器有附防水塞可買
因為光陽金吉邁500的點煙器插座貴很多>"<
使用道具
发表于 2007-11-12 03:14:53 | 显示全部楼层
你很厲害.哪天也交流一下!
推...
 楼主| 发表于 2007-11-12 10:07:25 | 显示全部楼层
懂些皮毛而已.以前做過電玩機台簡易維修的工作.
diy比較有成就感也省錢多了.來跟大家分享拙作罷了.
而且freeman的作品也給了很大的啟發.
发表于 2007-11-12 11:55:29 | 显示全部楼层
好厲害阿~我也去裝了點煙器 一組600
後來才知道頂客一組才200多~暈
路過的  发表于 2007-11-12 12:06:39
回覆給:*RV團團長*麒麟
我也是買200多..只是到電子材料行看到一樣的.只差在沒保險絲座
才5-60$我頭也暈了一下Orz
使用道具
路過的  发表于 2007-11-12 12:09:08
回覆給:SEGA
想請教一下..你接那個繼電器有何做用啊?^^
使用道具
 楼主| 发表于 2007-11-12 14:05:34 | 显示全部楼层
因為我的H4燈具電源來自原本的近燈H7.繼電器的功能是導入遠燈電源當作開關來切換H4的遠燈與近燈.
我為了這個繼電器的電路怎麼接.想了2天.
路過的  发表于 2007-11-12 19:57:18
回覆給:SEGA
繼電器要怎麼接呢!
我之前研究了好久..結果還是搞清楚>"<
使用道具
 楼主| 发表于 2007-11-14 23:38:30 | 显示全部楼层
我也是從這學來的.  寫的很詳細  http://fcuaa.fcu.edu.tw/~d8730281/ele.files/relay.htm
路過的  发表于 2007-11-15 19:28:11
回覆給:SEGA
謝你喔!我大概懂了^^
使用道具
GMT+8, 2025-5-16 03:27 , Processed in 0.068448 second(s), 20 queries .
