查看: 25873|回复: 11
2008 Suzuki Hayabusa
发表于 2007-7-9 15:40:55 | 显示全部楼层 |阅读模式
Recommended Retail Price (US): $11,999  (加稅後 $14,xxx)
Engine :
Bore :
Stroke :
Displacement :
Compression ratio :
Air Cleaner :
Starter :
Lubrication :
Fuelling :
Overall length :
Overall Width :
Height :
Wheel base :
Ground clearance :
Seat height :
Dry weight :
GMV :
In-line 4 cylinder 4 stroke DOHC TSCC
81.0 mm
65.0 mm
1340 cc
12.5 : 1
Non-woven fabric
Electric
Wet sump
Electronic Fuel Injection
2195 mm
740 mm
1170 mm
1485 mm
120 mm
805 mm
220 kg
xxx kg
Gearbox :
6 speed constant mesh
Wet multi-plate hydraulic clutch
Secondary reduction ratio 2.352
Drive chain RK GB50GSV Z3 112 Links
Suspension  (front) :
Inverted telescopic,
coil sprung, oil damped,
spring preload fully adjustable rebound damping force 14-way adjustable
compression damping force 13-way adjustable
Suspension  (rear) :
Link type, coil spring,
gas/oil damped,
spring preload fully adjustable force 22-way adjustable,
compression damping force 22-way adjustable
Caster :
Trail :
Steering angle :
Turning circle :
24* 12''
97 mm (3.8 in)
30* right to left
Suspension Settings :
STANDARD
Brakes / Tyres / Tyre Pressures:
310mm Tokico - Front twin 6 piston caliper
260mm Back single 4 piston caliper
Front 120/70 ZR17 Bridgestone BT-015
Rear 190/50 ZR17 Bridgestone BT-015
Fuel tank :
2008 : 21 litres Canadian : 20 litres
Fuel consumption :
Exhaust :
4 into 2 into 1into 2 (standard)
Colours :
GVM :.
Ignition type :
Spark plug :
Battery :
Generator :
Headlight :
Headlight :
turn signal :
Brake light tail light :
License plate light :
Dash lighs all :
Battery Type :
1st Gear :
2nd Gear :
3rd Gear :
4th Gear :
5th Gear :
6th Gear :
Power :
Torque :
200hp
15kg-m
Power switch with 3 settings (like GSXR1000)
Emmissions :
Euro 3 Tier 2
1 PS :
1 HP :
1 kW :
1 PS :
1 kg/m :
1 ft/lb :
1 Nm :
1 Nm :
0.98 HP
1.014 PS
1.36 HP
0.735 kW
7.23 ft-lb
0.138 kg-m
0.737 ft-lb
0.102 kg-m
The following is the Official Suzuki Description of the changes.
Redesigned instrument cluster now features four analog meters for speedometer, tachometer, fuel gauge and water temperature with a new S-DMS mode indicator, gear position indicator and adjustable engine rpm indicator.
New 1340cc, DOHC liquid-cooled engine with 16-valves, Twin Swirl Combustion Chambers provides 11% higher performance and smoother operation.
New Suzuki SDTV fuel injection system with dual injectors per cylinder and ram air intake with large volume airbox.
New S-DMS (Suzuki Drive Mode Selector) allows the rider to choose from three different engine settings depending on riding conditions or rider preferences.
New lightweight titanium intake and exhaust valves with narrow 14 degree valve angle for high combustion chamber efficiency.
New lightweight aluminium alloy pistons feature a revised shape and a higher compression ratio of 12.5:1 for maximum performance in all conditions.
SCEM (Suzuki Composite Electro-chemical Material) plated cylinders minimize cylinder size and improve heat dissipation and new hydraulic cam chain tensioner for reduced mechanical noise.
New ventilation holes at the cylinder skirt for reduced pumping losses and increased performance.
High efficiency curved radiator now features dual electric fans controlled by the ECM for increased cooling capacity. Oil cooler now has 10 rows cores for increased heat dissipation.
New large volume 4-2-1-2 exhaust system with a large capacity catalyzer, dual triangular canisters and closed loop system that meets Euro 3 and Tier 2 regulations.
New Shot-peened chrome-moly steel connecting rods for maximum durability.
All new aggressive aerodynamic fairing design with low drag coefficient retains it''s signature Hayabusa look and features an updated, muscular look to work with the new more powerful engine and updated chassis.
New fully adjustable inverted front fork featuring DLC coated inner tubes for minimal friction resistance and outstanding suspension performance over a variety of riding conditions.
Fully adjustable rear shock absorber with a 43mm piston and 14mm rod diameter.
Lightweight and rigid twin-spar aluminium frame minimizes weight while maintaining high torsional strength.
New bridged aluminium alloy swingarm features a new cross-sectional shape for increased rigidity and to cope with improved rear tire grip and increased engine output.
New radial-mount front brake calipers for maximum braking performance and allows for smaller 310mm front brake rotors resulting in reduced unsprung weight and improved handling
Lightweight single piston rear brake caliper working in conjunction with a new larger 260mm rear brake disc.
Newly designed wheels mounted with high performance Bridgestone BT-015 tires for unmatched handling and control.
Passenger seat and rear subframe are lowered for improved passenger comfort.
Fuel tank height is lowered to allow riders helmet to tuck in and windscreen height is increased for improved wind protection and optimum aerodynamic efficiency with the rider in place.
Newly designed vertically stacked twin headlights provide increased light intensity, improved light distribution and match the elegant flow of the new Hayabusa styling.
LED taillight utilizes a double lens structure with a clear inner lens and a red outer lens for maximum visibility and a high quality finish.
這裡有影片
http://sameerkumar.blogspot.com/2007/06/2008-suzuki-hayabusa-first-pic-and-some.html
发表于 2007-7-9 16:15:35 | 显示全部楼层
諸原的部分還能應付,下面的文字解說就霧傻傻.....   Orz
发表于 2007-7-9 18:07:21 | 显示全部楼层
SCEM 不是07年K7用的系統嗎??
发表于 2007-7-10 01:09:21 | 显示全部楼层
回覆給:Onizuka
SCEM對Suzuki來說不是什麼特別的技術...
從速克達到檔車不少車都有使用...
GSR125也是有使用
SCEM沒研究跟一般陶瓷汽缸的差異...反正就是Suzuki的陶瓷汽缸
對了...K7的7就是指07年的意思啦XDDD
新的嗨阿...屁股看起來好噁= ="
发表于 2007-7-10 21:23:06 | 显示全部楼层
屁股 超像 鴨子在 噁噁.....
发表于 2007-7-10 21:24:08 | 显示全部楼层
感覺 她有點 把後座給去掉的感覺
发表于 2007-7-10 22:18:09 | 显示全部楼层
也許是我思想邪惡.......
屁股很像 情趣用品..............@@
发表于 2007-7-11 06:12:57 | 显示全部楼层
屁股有點像拿雙槍的外星人= = "
发表于 2007-7-11 23:09:31 | 显示全部楼层
隼可是各國警方的愛用車呢看到很爽的
发表于 2007-7-12 01:05:55 | 显示全部楼层
這只是改裝車吧...
哪有警方會改原廠設定...
前碟還用浪花碟..
 楼主| 发表于 2007-7-12 03:23:25 | 显示全部楼层
美國阿拉班馬州的高速公路警察 ------  為什麼鄉下地方會有這個???
http://thekneeslider.com/archives/2006/05/25/suzuki-hayabusa-police-interceptor/
发表于 2007-7-14 04:09:54 | 显示全部楼层
回覆給:Wu
記得沒錯的話,第一張有浪花碟的車是廠商展示車
有沒有成交就不曉得囉
GMT+8, 2025-5-9 10:15 , Processed in 0.367079 second(s), 21 queries .
