查看: 1155|回复: 3
FZ6/R1 美國可以免費更新TPS耶
发表于 2007-1-26 13:39:39 | 显示全部楼层 |阅读模式
04~05年的FZ6/R1, 不管你有沒有過保固.
TPS的料號是新的, 原文如下 :
Symptom: On some units in the affected range, engine idling speed can become intermittently unstable after the engine
reaches operating temperature. Idle speed can drop to 500~600 rpm and the engine can stall if left idling.
Cause: Intermittent TPS (Throttle Position Sensor) internal contact.
Remedy: Replace the TPS with one of a new type as described in this bulletin.
Part Number       Part Name                                                        Qty. Dealer Cost
5FL-85885-02-00 TPS for FZS600 and YZF-R1 (includes new seal) 1      $70.99
July 26, 2006
Dear Yamaha Owner:
Yamaha strives to offer motorcycles with exceptional quality and performance, including the
YZF-R1 or FZ6 motorcycle shown on the label above. We thank you for purchasing this motorcycle
and hope that it is providing you with an enjoyable ownership experience.
Yamaha has determined that the Throttle Position Sensor (or “TPS”) on 2004 and some 2005
models may not function correctly. As a result, some owners have experienced an intermittently
unstable idle when the engine has reached operating temperature. The idle speed
might drop to 500 to 600 rpm, and the engine may stall if you do not give it throttle again.
To correct this unstable idle condition, Yamaha will replace the TPS on your motorcycle at no
cost to you for parts or labor, even if your motorcycle is out of warranty, and even if you have
never experienced this unstable idle condition.
To get the free TPS replacement, simply call your Yamaha motorcycle dealer and make an
appointment so he can be sure to have the parts in stock. The job takes a little less than
one and a half hours to perform, but your dealer may need to keep your motorcycle longer
depending upon his Service Department schedule.
Thank you again for owning a Yamaha. We know you have a choice in motorcycle brands
and appreciate that you have chosen to be part of the growing Yamaha family. Please take
advantage of this offer today by calling your dealer and scheduling the TPS replacement.
Sincerely,
Service Division
Customer Support Group
发表于 2007-1-26 15:14:10 | 显示全部楼层
回覆給:Pally
不知道台灣有沒有這樣的服務
发表于 2007-1-27 11:05:45 | 显示全部楼层
回覆給:Simon
在Taiwan...因為YAMAHA的車...不是YAMAHA代理進來的.....SO.....不用想了~!
发表于 2007-2-23 01:19:15 | 显示全部楼层
On some units in the affected range...
Yamaha YZF-R1 RN121-000658 to RN121-026567
Yamaha FZ6 Fazer RJ071-000757 to RJ071-039506
Yamaha FZ6N Naked RJ074-002681 to RJ074-028348
Yamaha XP500 TMax SJ031-001269 to SJ031-021166
Yamaha XP500 TMax SJ034-000301 to SJ034-002302
FYR.
GMT+8, 2025-4-3 17:14 , Processed in 0.276518 second(s), 21 queries .
