查看: 1967|回复: 5
KAWASAKI GTR 1400
发表于 2006-11-10 18:55:53 | 显示全部楼层 |阅读模式
Key Features:
- Most powerful production sport tourer
- Next generation monocoque aluminum frame
- Comfortable long distance riding position
- Low-maintenance shaft drive
1,352cc Four-Cylinder, DOHC Engine with Variable Valve Timing (VVT)
- Tuned to provide smooth power across a wide rev range
- Variable valve timing improves the engine’s flexibility and efficiency by altering the camshaft profiles to suit different rpm ranges
- Carefully planned engine design keeps it compact and narrow
- Chrome composite plated aluminum cylinder bores are lightweight, durable, and quickly carry heat away from the combustion chamber and piston for supreme durability under high loads
Gear-Driven Dual Engine Balancers
- Already in perfect primary balance, dual secondary balancers virtually eliminate unwanted vibrations for extremely smooth engine operation and enhanced rider comfort
Ram Air Induction
- Ram Air ducts produce a straighter path to the airbox for maximum intake efficiency
- This system takes cooler, high-pressure air, guides it through the air filter and into the engine for maximum power output
Digital Fuel Injection
- Throttle bodies are fitted with sub-throttle valves that are controlled by the ECU to provide smooth, precise response similar to constant velocity carburetors
- 32-bit electronic control unit works with dual throttle valve system to further enhance throttle response and control
- A digital computer feeds the engine exactly the amount of fuel it needs for cleaner emissions and maximum fuel economy
Digital Ignition
- Digital Timing Advance enhances low-and mid-range power
- Four individual spark plug-mounted ignition coils fire each spark plug independently to achieve the optimum timing for that cylinder at that instant
- ECU includes an idle speed control system for easier starting and warm-up
Radial Pump Clutch Master Cylinder
- Hydraulic clutch features a radial-pump clutch master cylinder for smooth and precise clutch engagement
Monocoque Aluminum Frame
- The frame is a hollow aluminum box that arches over the engine from the steering head to the swing arm pivot; it is narrow, strong, rigid and very light
- Engine is rigidly mounted to increase the monocoque’s torsional rigidity. Plus using the engine as a stressed frame member decreases the frame’s weight by approximately four pounds
- Engine positioned forward in the frame, wheelbase and front/rear weight balance were carefully designed to achieve high-speed stability and responsive handling
- Massive steering head casting contributes to frame rigidity
Radial-mount Petal-type Front Disc Brakes
- Radial mounted four-piston front brake calipers. Instead of mounting the calipers with threaded tabs cast near the top of the caliper, the radial design utilizes integrated mounting points at both the top and bottom of the caliper, with the mounting bolts inserted through the rear of the caliper instead of the side/front. This makes the caliper more rigid, which improves brake feel over a wider range of operation
- A separate brake pad is used for each piston. One large pad can deform with the heat generated by hard braking, resulting in a loss of brake feel at the lever. Individual pads provide increased cooling efficiency and can absorb more heat without deforming so they maintain consistent brake feel under extreme conditions
- Petal design front and rear brake rotors provide enhanced cooling and better warp resistance
- Radial-pump front brake master cylinder improves brake performance and lever feel
Tetra-Lever Shaft Drive
- Unique four-link design significantly reduces driveline lash during sport riding and provides smooth acceleration when exploiting the engine’s incredible power output
- Virtually maintenance free, the Tetra Lever system dramatically reduces routine maintenance requirements
Antilock Brake System (Concours™ 14 ABS)
- ABS brakes boost safety and rider confidence in low-traction conditions and may enhance evasive maneuvering in an emergency
Bodywork Optimized for Sport Touring
- Fairing design promotes smooth airflow around the rider and passenger with minimal buffeting
- Integrated, locking hard luggage offers plenty of storage, without disrupting the Concours 14’s style or performance
- Electrically adjustable vented windscreen
- Large, comfortable seat offers long-distance comfort for both rider and passenger
- Glove box mounted on the fuel tank cover
Full Instrumentation
- Easy to read speedometer and tachometer
- Multi-function LCD digital display includes an odometer, two trip meters, fuel gauge, gear position indicator and a clock
- A CAN (Controller Area Network) interface between the gauges uses fewer wires while allowing a greater volume of information, such as estimated fuel mileage, to be exchanged
- Kawasaki Smart key system (KI-PASS)
- Tire pressure sensors
2008 KAWASAKI CONCOURS™ 14 AND CONCOURS 14 ABS
在美國這輛叫做 concours, 是準備在2007年的年尾上市.  我覺得是KAWASAKI 要拿來跟 HONDA ST1300, YAMAHA FJR1300, BMW 等搶長途旅遊的那塊大餅.   售價可能會定在美金 $14,000~ $16,000
发表于 2006-11-10 18:58:49 | 显示全部楼层
回覆給:老外
軸傳動啊...
发表于 2006-11-10 21:29:47 | 显示全部楼层
回覆給:老外
還真的是FZ1的肥管。。。
 楼主| 发表于 2006-11-11 01:55:51 | 显示全部楼层
這裡有影片
http://video.google.com/videoplay?docid=2514697239151949058
回覆給:遊魂
軸傳動好阿
回覆給:名字不重要
我覺得看起來比 FZ 1 的管好看多了
发表于 2006-11-11 16:52:28 | 显示全部楼层
回覆給:老外
我是覺得好像是把FZ1的管拉長加前段...
因為FZ1看多了....感覺怪怪的=.=
如果能有多一點科技感的設計就好了
发表于 2006-11-11 19:38:46 | 显示全部楼层
啥!!!又是GTR....
GMT+8, 2025-5-10 07:43 , Processed in 0.085155 second(s), 20 queries .
