查看: 841|回复: 21
[07年新車]YZF-R1
发表于 2006-10-11 23:27:32 | 显示全部楼层 |阅读模式
Engine
Type998cc, liquid-cooled, 16-valve, DOHC, inline four-cylinder
Bore x Stroke77 x 53.6mm
Compression Ratio12.7:1
CarburetionFuel Injection with YCC-T and YCC-I
IgnitionTCI
Transmission6-speed w/multi-plate slipper clutch
Final Drive#530 O-ring chain
Chassis
Suspension/Front43mm inverted telescopic fork w/adjustable preload, compression damping, rebound damping; 4.7" travel
Suspension/RearSSingle shock w/piggyback reservoir; adjustable for hi-/lo-speed compression damping, rebound damping, spring preload
Brakes/FrontDual 310mm discs; radial-mount forged 6-piston calipers
Brakes/Rear220mm disc w/single-piston caliper
Tires/Front120/70-ZR17
Tires/Rear190/50-ZR17
Dimensions
Length81.1"
Width28.3"
Height43.7"
Seat Height32.9”
Wheelbase55.7”
Rake (Caster Angle)24.0°
Trail4.0”
Fuel Capacity4.75 gal.
Dry Weight381 lbs.
Other
Primary Reduction Ratio65/43 (1.512)
Secondary Reduction Ratio45/17 (2.647)
Gear Ratio - 1st Gear38/15 (2.533)
Gear Ratio - 2nd Gear33/16 (2.063)
Gear Ratio - 3rd Gear37/21 (1.762)
Gear Ratio - 4th Gear35/23 (1.522)
Gear Ratio - 5th Gear30/22 (1.364)
Gear Ratio - 6th Gear33/26 (1.269)
发表于 2006-10-12 01:05:19 | 显示全部楼层
回覆給:一水[74]-183匹
感覺那整流罩像沒靠緊的拼圖........還是喜歡以前全包的感覺.......
发表于 2006-10-12 01:06:02 | 显示全部楼层
到最後會不會乾脆把車架引擎做成有整流效果~連殼都省了....
发表于 2006-10-12 02:46:07 | 显示全部楼层
80年代開始的5汽門傳說
終於在2007年終結了嗎...
发表于 2006-10-12 03:06:42 | 显示全部楼层
居然變成16汽門了??!!
還有輻射卡鉗硬擠下3活塞系統= ="...
前面的進氣口加大..不過大的很不搭=D=..
還好我愛的是Kawasaki...哈哈哈哈哈!!
发表于 2006-10-12 19:25:23 | 显示全部楼层
邀受...前兩天在龜山往迴龍(台一線)的山路上...被一台寶紅色的R1追殺呼嘯而過勒.....
 楼主| 发表于 2006-10-12 19:28:05 | 显示全部楼层
回覆給:Jr.Frog
直接捨棄車架就好了.......
发表于 2006-10-12 20:27:31 | 显示全部楼层
回覆給:一水[74]-183匹
你是說那台傳奇中的傳奇嗎@@"~我很好奇那台的避震的連桿是怎麼運作的說~
 楼主| 发表于 2006-10-12 20:48:30 | 显示全部楼层
回覆給:Jr.Frog
不用想太多....就是把前剎直接鎖在引擎上面....其他都一樣....
http://www.zclub.com.tw/dis/bs_list.asp?BsNo=64497&cateno=7&indexpage=1&keyword=一水[74]-183匹
发表于 2006-10-12 22:01:24 | 显示全部楼层
回覆給:一水[74]-183匹
BMW的R1100S算嗎??
发表于 2006-10-13 01:44:59 | 显示全部楼层
回覆給:一水[74]-183匹
我說的是第一第二張圖的那個後避震~用連桿配置到引擎前下方~似乎對重心有不小的幫助~
发表于 2006-10-13 15:28:58 | 显示全部楼层
真是帥氣
h9
发表于 2006-10-13 15:29:29 | 显示全部楼层
真是帥氣
算是06年的 再改版
发表于 2006-10-13 18:03:24 | 显示全部楼层
很不協調的外型      ~"~
发表于 2006-10-13 20:27:57 | 显示全部楼层
還是一樣買不起的價錢
发表于 2006-10-14 00:25:51 | 显示全部楼层
可能大家看慣了包覆式的外殼
不過我覺得這樣做其實還不錯看
對散熱效果應該提升不少
只能說YAMAHA的設計實在是夠前衛~
发表于 2006-10-14 18:16:51 | 显示全部楼层
仔細看 其實07r1的進氣孔很漂亮呢
不知道這樣改變 馬力變多少...
发表于 2006-10-14 18:25:17 | 显示全部楼层
回覆給:【NewStyle】
強制進氣啟動下
最高馬力189P
鐵騎有詳細介紹 http://www.ibike.com.hk/01_bike_report/local/yama/07_r1/01.htm
发表于 2006-10-14 18:27:13 | 显示全部楼层
這張圖看起來真是殺氣十足阿
发表于 2006-10-14 21:51:43 | 显示全部楼层
回覆給:FF-K
果然變的更怪物了
買SP的人心裡可能會有點OS.....= ="
GMT+8, 2025-5-10 08:53 , Processed in 0.127471 second(s), 21 queries .
