查看: 436|回复: 4
aprilia af1??
发表于 2006-5-19 22:23:06 | 显示全部楼层 |阅读模式
aprilia af1~有人聽過這台車嗎?
有人有數據~跟圖片可以分享嗎~THX
发表于 2006-5-19 22:39:13 | 显示全部楼层
 楼主| 发表于 2006-5-19 22:45:03 | 显示全部楼层
回覆給:小紅馬溜溜車
有數據嗎~裡面只有圖
发表于 2006-5-19 23:11:05 | 显示全部楼层
回覆給: 黑羽
General information
Model:Aprilia AF1 125 Futura
Year:1991
Category:Sport
Rating:75 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement:125.00 ccm (7.63 cubic inches)
Engine type:Single cylinder
Stroke:2
Power:27.00 HP (19.7 kW)) @ 8800 RPM
Compression:15.0:1
Bore x stroke:54.0 x 54.5 mm (2.1 x 2.1 inches)
Fuel control:Membrane & variable discharge openings
Cooling system:Liquid
Gearbox:6-speed
Transmission type
final drive:
Chain
Physical measures
Weight incl. oil, gas, etc:140.0 kg (308.6 pounds)
Chassis and dimensions
Front tyre dimensions:100/80-17
Rear tyre dimensions:130/70-17
Front brakes:Single disc
Rear brakes:Single disc
Speed and acceleration
Top speed:158.0 km/h (98.2 mph)
Other specifications
Fuel capacity:20.00 litres (5.28 gallons)
 楼主| 发表于 2006-5-20 01:35:47 | 显示全部楼层
回覆給:NINJA-開聯結車的小飛俠-420匹
多謝啦~~
努力翻譯中~~
GMT+8, 2025-4-25 06:06 , Processed in 0.070300 second(s), 21 queries .
