查看: 1657|回复: 33
CBR150R??去填海吧~~~~~~~
发表于 2005-11-23 09:51:23 | 显示全部楼层 |阅读模式
2006 阿普利亞 RS-125
TECHNICAL CHART
Engine
Liquid cooled, single cylinder two stroke. Aluminium cylinder with Gilnisil coated liner. Read valve intake and exhaust port valve. Separate lubrication. Homologated to Euro 2 standards.
Bore by stroke
54 x 54.5 mm.
Displacement
124.8 cc.
Compression ratio
12.5 ± 0.5:1.
Carburettor
Dell’Orto PHBH 28.
Ignition
Electronic CDI ignition.
Starting
Electric.
Alternator
12 V – 180 W
Lubrication
Separate mixing with variable displacement, volumetric pump.
Gearbox
6 speed.
1st 10/30 (0.33)
2nd 14/29 (0.48 )
3rd 17/27 (0.63)
4th 19/25 (0.76)
5th 21/24 (0.87)
6th 22/23 (0.67)
Primary drive
Gearbox: 63/19 (3.31).
Final drive
Chain: 40/17 (2.35).
Clutch
Multi-disc in oil bath.
Frame
Cast aluminium, reinforced box section, sloping twin-spar frame.
Front suspension
Upside down hydraulic fork, Ø 40 mm. Wheel travel 120 mm.
Rear suspension
Cast aluminium box section swingarm with asymmetric members. Hydraulic monoshock with adjustable spring preload. Wheel travel 120 mm.
Brakes
Front: Floating Ø 320 mm disc. Radial caliper with four different diameter pistons, Ø 32 mm – Ø 27 mm.
Rear: Single Ø 220 mm disc. Caliper with two Ø 30 mm pistons.
Wheels
Aluminium alloy. Front 3.00 x 17”; rear 4,00 x 17”.
Tyres
Tubeless radial. Front 110/70 17”; rear 150/60 17”.
Dimensions
Overall length 1955 mm
Overall width (at handlebars) 720 mm
Overall height (at windshield) 1100 mm
Seat height 805 mm
Wheelbase 1345 mm
Tank
14 litres (3.5 litre reserve).
Colours
Aprilia Black, GP Aprilia White
㊣圖片及數據資訊轉貼於MOTOCITY  allblack 大大
发表于 2005-11-23 10:15:11 | 显示全部楼层
回覆給:Cris
:P
猛流口水~
可惜就算買的到也不能掛牌~>_<~ 泣…
還是CBR150卡實在啦~呵呵
 楼主| 发表于 2005-11-23 10:33:40 | 显示全部楼层
小綠快點買阿~~
发表于 2005-11-23 12:05:37 | 显示全部楼层
各方面都漂亮的小重車
品牌漂亮
車身漂亮
馬力漂亮
連價格都很漂亮...漂亮到你不敢買= ="
发表于 2005-11-23 15:10:47 | 显示全部楼层
回覆給:Cris
不知道小薛會不會後悔太早買= =|||
发表于 2005-11-23 15:36:03 | 显示全部楼层
回覆給:Cris
大哥
你怎麼見一台愛一台啦
Aprilia的這台車
命運跟Aprilia rs125一樣
台灣不能掛牌了啦
就算可以掛牌
他有可能跟cbr150一樣
只賣10來萬嗎
當然不可能
就算可能賣10來萬
零件也便宜不了吧
殘念
发表于 2005-11-23 17:38:18 | 显示全部楼层
這一台好帥
性能好像很讚~^^
但是...都是英文...我巄看無...(本人外語能力很差...)
有人翻譯一下嗎??
(我看沒有人理我..)
发表于 2005-11-23 20:57:24 | 显示全部楼层
一樣是用化油器!(我以為是2T缸內直噴耶....)
這樣歐洲國家等等的環保法過的了嗎?
发表于 2005-11-23 20:59:52 | 显示全部楼层
小薛買這台會更棒呀
換掉舊小獅吧@@
真的是很漂亮呀
跟TZR有點神似
是指他們都是小車有公升級的外觀
发表于 2005-11-23 21:24:24 | 显示全部楼层
連歐盟二期都過了,在台灣居然無法領牌...
唉...上面的"萎人"呀...
发表于 2005-11-23 23:56:55 | 显示全部楼层
只趕看不趕想
发表于 2005-11-24 09:19:28 | 显示全部楼层
cbr150r 跟這台不同屬性啦~
別說的這麼狠...填海=.=""
发表于 2005-11-24 09:49:23 | 显示全部楼层
這台rs125-完稅車...
要訂的話...30萬有找...(沒記錯的話)
发表于 2005-11-24 12:55:25 | 显示全部楼层
如果這台是乾式離合器加晶片卡啟動的話.會更屌
发表于 2005-11-24 15:21:36 | 显示全部楼层
這台車真是帥到爆了!!!125CC又有重車的架勢,真是完美啊
发表于 2005-11-26 02:58:42 | 显示全部楼层
請問為什麼不能在台灣掛牌呢.........??
发表于 2005-11-26 14:43:44 | 显示全部楼层
因為排氣驗不過~~~
发表于 2005-11-26 20:51:27 | 显示全部楼层
我想...全新的...
經過稍微的整理改裝 (就是整理排氣的部分)
應該是有辦法領牌吧^^
只是價格應該會更漂亮~(挑戰  cbr600rr..)
发表于 2005-11-26 23:50:26 | 显示全部楼层
回覆給:賤狗
我猜25萬左右
可是他是125
那還不如買cbr150 15萬以內...
发表于 2005-11-26 23:52:57 | 显示全部楼层
日本買rs125...小薛那台不是5x萬日幣...
不知道這台新款的在日本要多少錢?
來台灣?價格不知道要多多少?
GMT+8, 2025-4-24 14:51 , Processed in 0.143391 second(s), 21 queries .
