查看: 202|回复: 13
這台車...有點謎樣的感覺
发表于 2004-8-9 18:29:52 | 显示全部楼层 |阅读模式
04 MBK FlameX motorcycle specificationsMBK FlameX 2004
2004 MBK FlameX photo
Picture credits: MBK
2004 MBK FlameX
Larger picture
Discuss this bike
Write a review
Sell this motorcycle
Such bikes for sale
Rate this motorbike
This bike's rating
List related bikes
Tip a friend
General information
Model:MBK FlameX
Year:2004
Category:Scooter
Rating:Do you know this bike?
Click here to rate it. We miss 3 votes to show the rating.
Engine and transmission
Displacement:124.80 ccm (7.62 cubic inches)
Engine type:Single cylinder
Stroke:4
Power:10.99 HP (8.0 kW)) @ 8500 RPM
Torque:9.60 Nm (1.0 kgf-m or 7.1 ft.lbs) @ 7500 RPM
Compression:10.0:1
Bore x stroke:52.4 x 57.9 mm (2.1 x 2.3 inches)
Fuel control:SOHC
Cooling system:Air
Physical measures
Dry weight:114.0 kg (251.3 pounds)
Seat height:770 mm (30.3 inches) If adjustable, lowest setting.
Wheelbase:1,290 mm (50.8 inches)
Overall length:1,855 mm (73.0 inches)
Overall width:685 mm (27.0 inches)
Overall height:1,110 mm (43.7 inches)
Ground clearance:110 mm (4.3 inches)
Chassis and dimensions
Front tyre dimensions:110/70-12 47L
Rear tyre dimensions:120/70-12 58L
Front brakes:Single disc
Front brakes diameter:220 mm (8.7 inches)
Rear brakes:Expanding brake (drum brake)
Rear brakes diameter:150 mm (5.9 inches)
Speed and acceleration
Other specifications
Fuel capacity:7.10 litres (1.88 gallons)
Further information
Ask questionsEnter the 04 MBK FlameX discussion group
Related bikesGet a list of related bikes for comparison of specs
Loan costsApply online for low-cost motorcycle loans at E-LOAN
发表于 2004-8-9 19:54:40 | 显示全部楼层
這是啥阿..
難道又是大陸模仿的??@@..
发表于 2004-8-9 21:14:46 | 显示全部楼层
不是
mbk 是德國車廠
跟山葉有合約
此款車前一代為頂級迅光
不要看一個影生一個子  都是阿共仔的錯
发表于 2004-8-9 21:22:21 | 显示全部楼层
更正
MBK 為 義大利專攻速可達生產車廠
发表于 2004-8-10 14:14:23 | 显示全部楼层
喔..
我只知道歐規版的頂迅是雙槍避震..
名子就叫做CYGNUS..
发表于 2004-8-10 15:05:55 | 显示全部楼层
咦?CYGNUS?
這不是 勁戰剛上市用的名字嗎?
這張圖的車看起來也比較像YAMAHA的勁戰
发表于 2004-8-10 15:44:02 | 显示全部楼层
勁戰是Cygnus X,天鵝座X
光系列本來就是Cygnus ...
发表于 2004-8-10 20:46:25 | 显示全部楼层
這根本就是鵝嘛...~.~
发表于 2004-8-11 03:09:34 | 显示全部楼层
這不過是歐規的鵝~我手邊還有他們這款的碼表呢!>>>不是音叉標誌,也不是寫yamaha~!!
发表于 2004-8-11 09:19:40 | 显示全部楼层
這台其實就是歐規版的天鵝啊~
還有其他像是日本的Majesty系列~也改成叫Skyliner(180cc&400cc)
這是比較有名的~YAMAHA的速克達轉MBK的話都會換名字的~
发表于 2004-8-11 14:01:08 | 显示全部楼层
說真的
圖片方面我看不出來和天鵝有什麼差別= ="
发表于 2004-8-11 15:30:56 | 显示全部楼层
回覆給:芒果冰砂
因為他本來就是 ....
 楼主| 发表于 2004-8-11 15:48:48 | 显示全部楼层
有沒有MBK的官網可以看
我找不到
 楼主| 发表于 2004-8-11 15:50:37 | 显示全部楼层
04 MBK Skyliner 125 motorcycle specificationsMBK Skyliner 125 2004
2004 MBK Skyliner 125 photo
GMT+8, 2025-5-5 10:25 , Processed in 0.149578 second(s), 19 queries .
