查看: 1040|回复: 1
問機油一事
发表于 2004-8-3 21:20:01 | 显示全部楼层 |阅读模式
請問一下阿
機油的礦物油,要用哪種的比較好
還有
檔車有齒輪油嗎
发表于 2004-8-4 00:31:00 | 显示全部楼层
Bike care products
Cleaning and maintaining bikes
Regular cleaning should be a core part of your maintenance schedule, and not just because it helps motorbikes hold their resale value. A good wash and polish can reveal potential problems before they become crises.
As well as cleaning, it pays to look after your chain. Correctly adjusted and properly lubricated, the chain delivers optimum power to the back of the wheel. Use Shell Advance bike care products to get the most out of your bike.
Read tips from our experts on:
Cleaning your bike
Chain maintenance
Shell Advance Brake Cleaner can
Shell Advance Brake Cleaner & Engine Degreaser
Intensive degreaser for cleaning brakes, clutch and engine parts as well as dismantled engine components (if necessary, also for the pre-treatment of heavily soiled chains).
Removes brake scuffing, brake fluid, grease, oily dirt and resinified residues. Especially suitable for professional use in the workshop due to high evaporation rate. After use on parts which may corrode if unprotected, please make sure to apply the appropriate corrosion protection. Spray can with environmentally friendly propellant.
Shell Advance Silicone Spray can
High performance bike protection
Heat-resistance motorcycle care product for metal and plastic parts. Restores surface finish. Makes rubber and plastic surfaces water repellent. Effective, lasting care and protection. Spray can with environmentally friendly propellant.
Shell Advance Universal Spray can
Multi-spray "all in one"
Multi-spray for motorcycle maintenance, care and conservation. Loosens, cleans, lubricates and protects against corrosion and moisture. Loosens tight screws, bolts and other tight parts. Excellent grease dissolving properties. Due to very effective anti-corrosion additives reliable protection, especially during winter break. Also suitable for elimination of ignition problems as result of damp spark plug sockets, cables etc. Spray can with environmentally friendly propellant.
Shell Advance Contact Cleaner can
High performance contact cleaner
Special product for cleaning and degreasing all mechanical parts and systems (brakes, dry clutches, electrical points etc.). Dissolves oil, grease and other residues. Powerful, automatic cleaning action with strong dissolving properties. Rapid drying. Spray can with environmentally friendly propellant.
Shell Advance Helmet & Visor can
Cleaning foam for helmets & visors
Active cleaning foam for helmets, visors and plastic surfaces. Dossolves stubborn street dirt, remains of insects and grease. Physiologically safe, therefore suitable for cleaning visor interior.
Shell Advance Dry Chain Lube can
High adhesion dry chain lube
Oil- and fat free chain lube for all motorcycle chains operating under extreme conditions (very high pressure and thermal stress). Recommended for O-ring chains. Because of high “PTFE” concentration Shell Advance   Dery Chain Lube is absolutely water repellent and due to dry lubrication the product minimises the adherence of dirt. Spray can with environmentally friendly propellant.
Shell Advance Chain Cleaner can
High performance chain cleaner
Special product for cleaning of all types of motorcycle chains. Dissolves and removes mineral deposits like oil, greases etc. quickly and completely. Spray can with environmentally friendly propellant.
Shell Advance Ultra Chain can
High Performance White Spray for Motorcycle Chains
Shell Advance Ultra Chain is a solution/dispersion of synthetic grease and corrosion inhibitors, antiwear and adhesive additives and PTFE powder in aliphatic carbohydrates. It has been specifically developed to assure the highest lubrication performance of two-wheeler chains, also with O-rings. It is easy to use for ultimate wear protection even in racing conditions and has good water repellent properties. The additives used reduce the corrosion in the treated parts and are highly compatible with other components. The PTFE powder reduces the friction thereby maximising power output.
Shell Advance Bio Chain can
Special biodegradable grease for two-wheeler drive chains
Shell Advance Bio Chain is a modified vegetable oils solution with the addition of corrosion inhibitors, antiwear and adhesive additives in de-odorised carbohydrates. It has been specifically developed to lubricate two-wheeler chains, also with O-rings, while reducing the environment impact through high biological degradability. It is easy to use, low wear and has good water repellent properties. The additives used reduce the corrosion in the treated parts, are highly compatible with other components while being environmentally friendly by nature.
Shell Advance Bike Cleaner can
High performance bike cleaner
Special cleaning agent for the whole bike. Cleans thoroughly with gentle cleansing action, lifting the dirt away. Can be washed off with water after a short action time. To a large extent also removes grease automatically. Improves paint gloss. Spray can with environmentally friendly propellant.
都好
僅供欣賞
GMT+8, 2025-5-18 05:22 , Processed in 0.091749 second(s), 19 queries .
