查看: 264|回复: 3
有誰有moto gp賽車的桌面啊???
发表于 2004-6-8 09:32:56 | 显示全部楼层 |阅读模式
請問各位有在收集motogp賽車圖片的大哥們可以分享一些圖片嗎??nsr500.rc211v.m1........等這些車都滿讚的想要收集一下~~謝謝
发表于 2004-6-8 09:41:10 | 显示全部楼层
发表于 2004-6-8 10:43:25 | 显示全部楼层
圖片?
用POWERDVD..一邊播一邊抓.
要多少有多少
发表于 2004-6-12 19:51:46 | 显示全部楼层
這是 因為被鎖的IP都被丙大解開,從此誓死捍衛丙大管理權的負負得正在2004/6/12 下午 06:27:35時留下的留言 電子郵件IP:61.63.92.37
YAMAHA YZR M1
Carlos Checa in MotoGP actionYZR-M1 MotoGP MachineYZR-M1 Data-loggerChassisYZR-M1 Side view
Engine
Engine type:Liquid-cooled, in-line, 4-cylinder, 4-stroke with 20-valve DOHC
Displacement:990cc
Ignition:Yamaha CDI with adjustable mapping - NGK spark plugs
Carburation:Fuel injection - Magneti Marelli
Lubrication system:Wet sump - Motul Oils
Data recording:2D
Maximum power:More than 210hp
Maximum speed:Over 320 km/h
Transmission
Type:6-speed cassette-type gearbox, with alternative gear ratios available
Primary drive:Gear
Clutch:Dry multi-plate slipper clutch
Final drive:Chain - DID
Chassis and running gear
Frame type:Twin-spar aluminium frame, multi-adjustable steering geometry, wheelbase, ride height, with aluminium swingarm
Front suspension:Fully-adjustable Öhlins inverted telescopic forks
Rear suspension:Braced aluminium swingarm with single Öhlins shock and rising-rate linkage
Front/rear wheels:Marchesini 17.0 inch front, 16.5 inch rear, available in a variety of rim widths
Front/rear tires:Michelin, 17.0 inch front, 16.5 inch rear, available as slick, intermediate, wet and hand-cut tyres
Front brake:Twin 320mm carbon discs with radial mounted four-piston Brembo calipers
Rear Brake:Single 220mm ventilated stainless steel disc with twin-piston Brembo caliper
Weight:145kg, in accordance with FIM regulations
Fuel capacity:
24 litre
1/12模型
當作是M1特集,一次看到爽吧!!
這是 因為被鎖的IP都被丙大解開,從此誓死捍衛丙大管理權的負負得正在2004/6/12 下午 06:32:09時留下的留言 電子郵件IP:61.63.92.37
再補4張!!
GMT+8, 2025-5-1 23:22 , Processed in 0.099040 second(s), 19 queries .
