查看: 322|回复: 12
NRS吃什麼油好阿
发表于 2004-6-2 13:42:00 | 显示全部楼层 |阅读模式
請問各位大大的NSR都加什麼牌的機油阿?? 還有..92.95.98哪種效果好?? 謝謝...
发表于 2004-6-2 14:06:33 | 显示全部楼层
Shell Advance 2 Stroke Oils
Shell Advance Racing M
Advance Racing M
A high performance castor/synthetic, SAE30 oil for 2-stroke racing motorcycle engines. Shell Advance Racing M is specifically formulated for highly stress conditions experienced in speedway motorcycles and go-karts burning alcohol/methanol fuel mixtures. The castor/synthetic blend ensures longer life than a straight castor oil. It can also be used in separate 2-stroke race gearboxes.
Shell Advance Racing X2
Advance Racing X2
A unique, Ester/PAO 100% synthetic, 2-stroke extreme performance engine oil, specifically formulated for the most extreme race conditions. Shell Advance Racing X2 can provide. Pre-mixing ratios up to 50:1 are achievable after consultation with your manufacturer's handbook.
Shell Advance VSX2
Advance VSX2
A fully synthetic super high performance, JASO FC rated 2-stroke motorcycle engine oil that gives superior protection for all modern 2-stroke motorcycle engines. Shell Advance VSX2 is formulated with polyisobutylene synthetic fluids that ensure a low smoke, low ash performance, superior lubrication and engine cleanliness under high pressure. It also provides excellent resistance to exhaust system blockages. It is suitable for both air and water cooled 2-stroke engines with oil-injection or pre-mix systems. Pre-mixing ratios up to 50:1 are achievable after consultation with your manufacturer's handbook.
Shell Advance SX2
Advance SX2
A synthetic fortified, JASO FB 2-stroke motorcycle engine oil that provides extra performance and protection for hard working 2-strokes that require smoother, cleaner performance. Suitable for both air and water-cooled production motorcycles with either pre-mix or oil injection systems, especially older 2-strokes that experience ring sticking and piston scuffing. Pre-mixing ratios up to 50:1 are achievable after consultation with your manufacturer's handbook.
Back to TopBack to Top
Shell Advance 4 Stroke Oils
Shell Advance Ultra 4
Advance Ultra 4
A race-proven, high performance, 100% synthetic, 10W-40 4-stroke motorcycle engine oil for those who demand absolute maximum power and performance. A championship winner as used in the Shell Advance World Superbike Ducati team.
Shell Advance VSX4
Advance VSX4
A fully synthetic, 15W-50, 4-stroke super high performance engine oil recommended for modern, air and water-cooled bikes. Shell Advance VSX4 is formulated with Shell's unique XHVI synthetic fluid renowned for maintaining an optimum lubricant film under extreme pressures and ensuring superior engine cleanliness, thereby extending your bike engine's life. Shell Advance VSX4 exceeds the latest JASO (MA) friction test for wet clutches.
Shell Advance S4
Advance S4
A 20W-50, 4-stroke mineral oil specifically formulated for the protection of older motorcycle engines that require a heavier blend. It is suitable for "running in" new or modified engines, or where the manufacturer requires a high quality mineral oil.
僅供參考
发表于 2004-6-2 14:14:34 | 显示全部楼层
我用海灣全合成2T
一罐300
經很多車友TIS跑下來
都說很不錯
爆發力強又不會積碳
潤滑性也很好
其他全合成好用的有魔特800.培力h1r.....等等
價錢你可能沒辦法接受.......=.=''
发表于 2004-6-2 17:46:59 | 显示全部楼层
海灣全合成2T機油幫浦可以加嗎?
還是一定要預混呢?
发表于 2004-6-3 14:00:46 | 显示全部楼层
預混或噴合都很好用阿^^
发表于 2004-6-3 15:03:05 | 显示全部楼层
我也想知道到底該用92還是95
我一直都加95
但有人說應加92
請問到底該加哪種?
发表于 2004-6-3 16:41:53 | 显示全部楼层
既然都習慣加95了就用95吧~~~~再去加92的話你可能會感覺到沒什麼力(雖然貴了點)
发表于 2004-6-3 17:07:37 | 显示全部楼层
有差嗎?二行程壓縮比這麼低...我個人是覺得92就ok了...95跟92用起來動力還會有差喔?不會吧??
发表于 2004-6-4 02:34:37 | 显示全部楼层
那再問現在能換92嗎?
還是會像ljs車友說的會變沒力?
发表于 2004-6-4 10:30:14 | 显示全部楼层
我前面2位車主都是加95的、到我手上才換92
跑起來還是很順,不會變弱啦
发表于 2004-6-7 07:24:39 | 显示全部楼层
了解,感謝各位賜教~
发表于 2004-6-7 10:44:24 | 显示全部楼层
我的車買來就吃92,騎了5萬公里了一點問題也沒有。他的壓縮比才7點多比1,吃95太浪費了,而且實際上很難感覺出來其中的差異。
发表于 2004-6-7 17:00:21 | 显示全部楼层
GMT+8, 2025-4-20 13:22 , Processed in 0.306785 second(s), 19 queries .
