查看: 476|回复: 3
教教我吧!~拜託各位車神!
发表于 2002-12-1 00:00:00 | 显示全部楼层 |阅读模式
請問一下ㄛ! 我這裡有一台k6~請問各位大大可以教我如何調鳥仔嗎? 從頭到尾~還有因注意哪些事項呢~? 我這裡還有一台k5~請問一下熱車時怠速正常~可是到大約每30秒怠速就會下降一下~然後又升回來~頻率大約每30秒一次~請問是啥摸原因? 還有請問一下k5ㄉOD檔是怎樣~?可以跟我介紹一下嗎~? 拜託各位大大嘍!
回覆給:言仔~
嗯..這邊好像不是4輪討論區喲
調鳥仔..找技師啊..因為要用到正時燈.一般人沒工具是很難調ㄉ
近排氣分開調.第一缸上死點.調....................☆■◎⊙℃>÷∞。π**
嗯..蠻複雜ㄉ..我很久沒調ㄌ..有些細節也忘ㄌ..
K5ㄉ症狀應該是油路ㄉ問題吧.不然就要檢查電系正不正常.有可能是發電機.一直在作動.....除非你跟我一樣是玩EF9四代喜美.16V.我就能教你調他ㄉ化油器...可惜.K5是噴射ㄉ啊
OD..是指over drive. 屬於齒比很低ㄉ檔..
是用來高速低轉巡航省油用ㄉ
因為我只開手排ㄉ.所以有些自排ㄉ問題我也不清楚
发表于 2002-12-4 00:00:00 | 显示全部楼层
QQQQQQQQQQQQQoooooooooooooooQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQoooooooooQQQQQQQQQQQQQQoooooooooqqqqqqqQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
QQQQQQQQQQQQQoooooooooooooooQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQoooooooooQQQQQQQQQQQQQQoooooooooqqqqqqqQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo回覆給:言仔~
GMT+8, 2025-5-17 22:47 , Processed in 0.076462 second(s), 20 queries .
